1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 28 29 30 31 32 33 34 35
Lubomir
Příspěvků: 165
Zpráva odeslána: 24. 6. 2012 o 01:12 | odkaz na příspěvek
Platí do 8.7.2012
2mm Gold Connectors 10 pairs (20pc)
http://www.hobbyking.com/buddy.asp?code=75D6F02A-3504-4641-BA01-EA18737B2438 Save US$: 0,38
Turnigy 5mm Hex Socket Screwdriver
http://www.hobbyking.com/buddy.asp?code=326B7827-A197-485C-95AA-5A97E6EFB9A4 Save US$: 0,59
Turnigy Pure-Silicone Wire 24AWG (1mtr) Blue
http://www.hobbyking.com/buddy.asp?code=EEEA0C6D-48BA-488F-8E57-488953582215 Save US$: 0,37
Turnigy 2mm Heat Shrink Tube Blue (1mtr)
http://www.hobbyking.com/buddy.asp?code=96D83463-A9D4-4F0F-A742-E8BB8E592E7A Save US$: 0,21
Turnigy 3mm Heat Shrink Tube Blue (1mtr)
http://www.hobbyking.com/buddy.asp?code=B1FC78C6-D0F3-4C4C-9292-500719500B87 Save US$: 0,21
Turnigy 4mm Heat Shrink Tube Blue (1mtr)
http://www.hobbyking.com/buddy.asp?code=DC22545A-7E83-44EA-8C33-E61835BD9268 Save US$: 0,20
Turnigy 5mm Heat Shrink Tube Blue (1mtr)
http://www.hobbyking.com/buddy.asp?code=094DA064-8F35-424C-98BD-5FA37B496E58 Save US$: 0,19
Turnigy 5mm Heat Shrink Tube Yellow (1mtr)
http://www.hobbyking.com/buddy.asp?code=B577BBD0-EA81-40BD-95EC-989F86817BA7 Save US$: 0,19
watson220
Příspěvků: 1151
Zpráva odeslána: 29. 6. 2012 o 22:35 | odkaz na příspěvek
Lubomir
Příspěvků: 165
Zpráva odeslána: 7. 7. 2012 o 16:11 | odkaz na příspěvek
Platí do 21.7.2012
http://www.hobbyking.com/buddy.asp?code=89B0B86E-27E3-4AE4-A9C4-031CF4DE78E2 Save US$: 0,43
GWS EP Propeller (RD-8043 203x109mm) (6pcs/set)
http://www.hobbyking.com/buddy.asp?code=DB597CDD-5F99-42CA-8AE5-1F86DA087DCC Save US$: 0,48
GWS EP Counter Rotating Propeller (RH-8043 203x109mm) (6pcs/set)
http://www.hobbyking.com/buddy.asp?code=479B141E-CE31-4025-8DCC-97AE1CEFB806 Save US$: 0,97
M4 Nylon Nut (10pcs/bag)
http://www.hobbyking.com/buddy.asp?code=A9891D65-D4DA-469D-9F84-2A08B844BEA9 Save US$: 0,10
Non-Adhesive Velcro (1 Set)
http://www.hobbyking.com/buddy.asp?code=D1227CFE-6164-4744-858A-6E152B257CF6 Save US$: 0,30
5.6mm x 15mm M3 Nylon Tapped Spacer (10pc)
http://www.hobbyking.com/buddy.asp?code=64CEEDC9-2EB2-4521-9560-135625F2AFED Save US$: 0,44
3mm Prop Saver w/ Adapter & 3 bands
http://www.hobbyking.com/buddy.asp?code=73D7C9B2-30C1-4534-A363-583FD11C345F Save US$: 1,05
Bearing 3x7x3mm (4pcs/bag) HK-550GT
http://www.hobbyking.com/buddy.asp?code=A0DF45BE-ED15-4A3A-86E2-7A1143D15643 Save US$: 0,42
cypo.sk
Příspěvků: 80
Zpráva odeslána: 17. 7. 2012 o 10:27 | odkaz na příspěvek
Extra Codes, You can save 30.67% for all of this products with:http://rc-buddy.com/user/cypo.sk! Codes from RC-Buddy.com
FrSky Battery Voltage Sensor - FrSky Telemetry System.
Savings: 30.67 % / $1
Price after: $2.26
Weight: 17 g
mat
Příspěvků: 69
Zpráva odeslána: 17. 7. 2012 o 13:35 | odkaz na příspěvek
Plati do 27.7.2012
Extra Codes, You can save 53.22% for all of this products with:http://rc-buddy.com/user/mat! Codes from RC-Buddy.com
SF E-Prop 8x3.8 / 203x96.5mm w/ Adapters Black (5pcs/bag) Savings: 30.11 % / $0.84 Price after: $1.95 Weight: 47 g
SF E-Prop 10x4.7 / 254x119.5mm w/ Adapters Black (5pcs/bag) Savings: 14.38 % / $0.43 Price after: $2.56 Weight: 73 g
Peel-n-stick foam tape. 10x5inch 4mm thick Savings: 83.89 % / $1.25 Price after: $0.24 Weight: 27 g
TURNIGY Plush 12amp (2A BEC) BESC Savings: 97.6 % / $9.77 Price after: $0.24 Weight: 35 g
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) Savings: 5.66 % / $0.09 Price after: $1.50 Weight: 30 g
GWS EP Propeller (RD-8043 203x109mm) (6pcs/set) Savings: 23.75 % / $0.95 Price after: $3.05 Weight: 55 g
Magnetic screws/parts Tray Savings: 12.89 % / $0.37 Price after: $2.50 Weight: 50 g
Wing Tape 45mic x 24 mm x 100m (Narrow - Blue) Savings: 36.19 % / $0.38 Price after: $0.67 Weight: 146 g
Bydlisko: Rajecké Teplice / Žilina / Piešťany ( 43 rokov )
Lubomir
Příspěvků: 165
Zpráva odeslána: 20. 7. 2012 o 14:50 | odkaz na příspěvek
Platnost do 1.8.2012
8X4R Propellers (Standard and Counter Rotation)
http://www.hobbyking.com/buddy.asp?code=18360790-4FD3-4678-82B1-18760E26E864 Save US$: 0,66
Spare Shaft for 24gram HXM2730 Motor
http://www.hobbyking.com/buddy.asp?code=CE123BDD-12B2-4D31-8E60-F40899882716 Save US$: 0,98
3.3V 3A UBEC - 2~5S Lipoly (6-23v)
http://www.hobbyking.com/buddy.asp?code=453767E2-C656-42DD-A0C4-871B78730E9C Save US$: 0,18
GWS EP Propeller (RD-1047 254x119mm) (6pcs/s)
http://www.hobbyking.com/buddy.asp?code=A52B33FC-76C0-4EF0-8ADD-E3F7174B2C8D Save US$: 0,72
Platnost do 3.8.2012
NTM Prop Drive 2826 Series Replacement Shaft
http://www.hobbyking.com/buddy.asp?code=70CE4B48-F77C-4F3C-B503-1AEB02DA0A77 Save US$: 0,41
M3 Nylon Nut (10pcs/bag)
http://www.hobbyking.com/buddy.asp?code=5E89EDC4-A765-44C2-82AD-0ED21FFED28B Save US$: 0,08
M3x8 Nylon Screws (10pcs/bag)
http://www.hobbyking.com/buddy.asp?code=4BD57DA6-F8AD-4932-B514-864D40E96FA8 Save US$: 0,09
MarkAurel
Příspěvků: 418
Zpráva odeslána: 21. 7. 2012 o 08:00 | odkaz na příspěvek
watson220
Příspěvků: 1151
Zpráva odeslána: 23. 7. 2012 o 17:46 | odkaz na příspěvek
Platnosť do 8.5.2012
Batéria LIPO ZIPPY Flightmax 4000mAh 4S1P 40C
http://www.hobbyking.com/buddy.asp?code=9A56090A-CBA1-4669-9BAC-C6FC38243905
Batéria LIPOTurnigy 1300mAh 3S 20C Lipo Pack
http://www.hobbyking.com/buddy.asp?code=6FCA53BB-6092-4AC8-B845-22F8475464DF
Lubomir
Příspěvků: 165
Zpráva odeslána: 28. 7. 2012 o 23:44 | odkaz na příspěvek
Platnost do 121.7.2012
10CM Male to Male Servo Lead (JR) 26AWG (10pc)
http://www.hobbyking.com/buddy.asp?code=36750E06-80D2-412A-9646-FFA421DDF398
HXT Lipo Monitor 4S. A must have for all lipo users!
http://www.hobbyking.com/buddy.asp?code=BEA468D2-8F56-4AFD-AD58-6284C381C4B6
M3x12mm Nylon Screws (10pcs/bag)
http://www.hobbyking.com/buddy.asp?code=57E188E4-513C-4048-BA1D-A92E1F0CB90F
olisoft
Příspěvků: 322
Zpráva odeslána: 30. 7. 2012 o 08:24 | odkaz na příspěvek
Lubomir
Příspěvků: 165
Zpráva odeslána: 3. 8. 2012 o 17:33 | odkaz na příspěvek
Platnost do 17.8.2012
8x4 Propellers (5Pcs/Bag)
http://www.hobbyking.com/buddy.asp?code=D8F5FC16-4C12-4DBA-A2F8-A9C44A69CA50 Save US$: 0.47
Turnigy Turnbuckle Wrench 4mm
http://www.hobbyking.com/buddy.asp?code=67A9BA92-87C9-4B3E-88C0-0FF5DFEEBF0F Save US$: 0.39
Turnigy Turnbuckle Wrench 5mm
http://www.hobbyking.com/buddy.asp?code=D692E672-8C6E-484A-8FCE-68B15B7B9777 Save US$: 0.44
mapesk
Příspěvků: 5
Zpráva odeslána: 10. 8. 2012 o 23:50 | odkaz na příspěvek
gemini
Příspěvků: 3
Zpráva odeslána: 14. 8. 2012 o 09:35 | odkaz na příspěvek
Extra Codes, You can save 11.9% for all of this products with:http://rc-buddy.com/user/gemini! Codes from RC-Buddy.com
Corona DS238MG Digital Metal Gear Servo 4.6kg/ 22g/ 0.14sec
Savings: 5.42 % / $0.43
Price after: $7.50
Weight: 45 g
Carbon Fiber Rod (solid) 2.5x750mm
Savings: 64.44 % / $0.87
Price after: $0.48
Weight: 8 g
Carbon Strip 1x3x750mm (5pcs/set)
Savings: 35.94 % / $1.47
Price after: $2.62
Weight: 17 g
Carbon Strip 0.5x3x750mm (5pcs/set)
Savings: -60.74 % / $-0.99
Price after: $2.62
Weight: 11 g
Carbon Fiber Rod (solid) 1.5x750mm
Savings: -51.52 % / $-0.51
Price after: $1.50
Weight: 4 g
Carbon Fiber Rod (solid) 1x750mm
Savings: 75.76 % / $0.75
Price after: $0.24
Weight: 4 g
Extra Codes, You can save 26.25% for all of this products with:http://rc-buddy.com/user/gemini! Codes from RC-Buddy.com
GWS EP Propeller (DD-5030 127x76mm) (6pcs/set)
Savings: 27.65 % / $0.94
Price after: $2.46
Weight: 21 g
JST Female 2 pin connector set (10pcs/set)
Savings: 32 % / $0.24
Price after: $0.51
Weight: 15 g
JST Male 2 pin connector set (10pcs/set)
Savings: 42.7 % / $0.38
Price after: $0.51
Weight: 13 g
Turnigy High Density R/C LED Flexible Strip-Red (1mtr)
Savings: 15.38 % / $0.62
Price after: $3.41
Weight: 59 g
HXT900 Replacement Gear Set
Savings: 46.07 % / $0.41
Price after: $0.48
Weight: 5 g
Nylon & Pinned Hinge 20x36 (10pcs)
Savings: 24.17 % / $0.29
Price after: $0.91
Weight: 17 g
Nylon & Pinned Hinge 16x28.5 (10pcs)
Savings: 30.33 % / $0.37
Price after: $0.85
Weight: 9 g
Extra Codes, You can save 61.29% for all of this products with:http://rc-buddy.com/user/gemini! Codes from RC-Buddy.com
Master Airscrew propeller 10x5
Savings: 33.47 % / $0.8
Price after: $1.59
Weight: 27 g
TGS Sport 10x5E Precision propeller
Savings: 72.27 % / $1.59
Price after: $0.61
Weight: 65 g
APC Style Propeller 10x5 (2 pc)
Savings: 23.79 % / $0.54
Price after: $1.73
Weight: 57 g
Price after: $2.56
Weight: 73 g
HobbyKing Super Glue CA (50g / 1.7oz) <b>Medium</b>
Savings: 57.64 % / $1.32
Price after: $0.97
Weight: 89 g
Rhino 1550mAh 3S 11.1v 20C Lipoly Pack
Savings: 89.94 % / $8.67
Price after: $0.97
Weight: 170 g
cypo.sk
Příspěvků: 80
Zpráva odeslána: 15. 8. 2012 o 09:40 | odkaz na příspěvek
MarkAurel
Příspěvků: 418
Zpráva odeslána: 17. 8. 2012 o 07:39 | odkaz na příspěvek
  • 412 ľudí online za poslednych 5 minút.
