1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 28 29 30 31 32 33 34 35
gemini
Příspěvků: 3
Zpráva odeslána: 26. 4. 2012 o 17:38 | odkaz na příspěvek
Nylon T-Connectors 10 Pairs (20pc)
http://www.hobbyking.com/buddy.asp?code=C948F99E-A4CF-4075-97AC-380AB1854728
18-11 2000kv Micro Brushless Outrunner (10g)
http://www.hobbyking.com/buddy.asp?code=537E2B25-3E88-423F-B85A-008E7C151C7B
TURNIGY Plush 6A /.8bec/6g Speed Controller
http://www.hobbyking.com/buddy.asp?code=A14DE457-8544-4672-8019-763E31D546A6
TURNIGY V-Tail Mixer. Ultra-small
http://www.hobbyking.com/buddy.asp?code=83671509-A892-433D-B7BE-2D40FBAF5671
GWS EP Propeller (DD-5030 127x76mm) (6pcs/set)
http://www.hobbyking.com/buddy.asp?code=CA98004C-F825-4D93-894C-DFE96A9F655B
GWS EP Propeller (DD-6030 152x76mm) (6pcs/set)
http://www.hobbyking.com/buddy.asp?code=DD06F4AE-3622-42CF-BBF2-20408DA6ACDE
Simple Prop Balancer
http://www.hobbyking.com/buddy.asp?code=47BD0FD1-67D5-4910-AB64-5D81C2008770
APC Style Propeller 5x5 (2 pc)
http://www.hobbyking.com/buddy.asp?code=AC691774-DE23-4E03-86E4-46DC7D65AD29
TGS Sport 5x5E Precision propeller
http://www.hobbyking.com/buddy.asp?code=343DDC8C-5652-405C-8501-0AB0948AC463
GWS EP Propeller (RD-6050 152x125mm) (6pcs/set)
http://www.hobbyking.com/buddy.asp?code=B43ECA4D-7171-4BB7-BCEB-3785987FCEE5
HXT500 5g / .8kg / .10sec Micro Servo
http://www.hobbyking.com/buddy.asp?code=326AE324-B69C-404B-B5BC-8C640C18DC09
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
http://www.hobbyking.com/buddy.asp?code=D9716605-11FA-4983-A41F-30C36270B3EF
Lithium Polymer Charge Pack 18x22cm Sack
http://www.hobbyking.com/buddy.asp?code=EDBFE92F-C9BB-4289-A571-884DE03029D8
On-Board Lipoly Low Voltage Alarm 2s~3s
http://www.hobbyking.com/buddy.asp?code=B480314D-F14B-49D1-A88D-B7ECDC54F0AD
Battery Tape (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code=7F4F870F-D8FC-4551-852A-E64E8C335DBD
0.8mm Gold Connectors 12 pairs (24pc)
http://www.hobbyking.com/buddy.asp?code=A4E722DB-B969-43AE-B5F7-545015ED9683
Prop Saver w/ Band 2mm (10pcs)
http://www.hobbyking.com/buddy.asp?code=24C4CA7D-E2A2-446A-B8C1-B6786B72A07D
Turnigy 2mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?code=0935D237-6EF5-48DA-BCEF-218B78B9832F
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)
http://www.hobbyking.com/buddy.asp?code=59F25A58-9DFF-49B0-8719-37B288CF626C
APC Style Propeller 8x6 (2 pc)
http://www.hobbyking.com/buddy.asp?code=7739A3E6-ABE6-4BE5-9D11-CF16C15BF93A
TGY Slow Fly Prop 8*6SF w/ shaft adapters
http://www.hobbyking.com/buddy.asp?code=F1E4933B-93C5-4C75-AFD0-ABCCA8D3AB06
TP Slow Fly propeller 8x6
http://www.hobbyking.com/buddy.asp?code=75A2CFC7-B599-45AD-B0EF-050B168F3C66
APC style propeller 8x6-E
http://www.hobbyking.com/buddy.asp?code=24E2DB6C-046A-4438-A1D1-63024D37893E
GWS V-Tail Mixer II (200 step)
http://www.hobbyking.com/buddy.asp?code=C766272F-793C-4538-9DA5-B7B3229BD073
3.17mm Prop Saver w/ Adapter & 3 bands
http://www.hobbyking.com/buddy.asp?code=CDA7E646-3D62-4A69-A649-1B5609C2EA08
Rhino 610mAh 2S 7.4v 20C Lipoly Pack
http://www.hobbyking.com/buddy.asp?code=67D1FB0B-4B8B-4DC8-8EC5-C5FB99A09A3B
NTM Prop Drive Series 35-36B 1400Kv / 495W
http://www.hobbyking.com/buddy.asp?code=9625435E-8627-4995-B1A1-38F7B091570C
TURNIGY Plush 40amp Speed Controller
http://www.hobbyking.com/buddy.asp?code=1B8AF81E-373C-4854-A6B2-8BE99A2BA8AE
APC style propeller 9x6-E
http://www.hobbyking.com/buddy.asp?code=373A9302-7E64-4CB9-850D-01C78448FC1B
Clear Foam Glue (Medium Cure) - Small 20g
http://www.hobbyking.com/buddy.asp?code=51A55CE0-8270-4D96-9D49-67ECF2FFF10F
cypo.sk
Příspěvků: 80
Zpráva odeslána: 30. 4. 2012 o 09:55 | odkaz na příspěvek
Find my codes here: http://hk.rc-international.info/swarm/cyposk (valid until May 14, 2012)
FrSky DHT-U Telemetry System Save US$: 7.02
ERIDANY
Příspěvků: 52
Zpráva odeslána: 4. 5. 2012 o 12:18 | odkaz na příspěvek
http://hk.rc-international.info/swarm/ERIDANY
TGY-1440A Turnigy 1440A Servo 4.4g/1.0kg/.10sec V2 (DE 3 Reserved
Z10003S25C ZIPPY Flightmax 1000mAh 3S1P 25C (DE Warehou 1 Reserved
TGY-1501MG Turnigy Metal Gear Servo 60g/15.5kg/.16sec ( 3 Reserved
TITAN-ARR Turnigy Titan 1/5 Scale 28CC Monster Truck ( 1 Reserved
HK-GT2 Hobby King GT-2 2.4Ghz 2Ch Tx & Rx (DE Wareh 1 Reserved
80T-ARR Turnigy Trailblazer 1/8 4WD Brushless Monste 1 Reserved
tu sú k tomu buddy :
Ak niekto bude objednávať cez moje buddy nech mi napíše. Ak mi príde bonus, bude ho mať u mňa...
Chcem to spätne skontrolovať či to správne funguje, lebo v poslednom čase nejak málo bonusov chodí...
eridany@eridany.sk
olisoft
Příspěvků: 322
Zpráva odeslána: 11. 5. 2012 o 21:43 | odkaz na příspěvek
cypo.sk
Příspěvků: 80
Zpráva odeslána: 12. 5. 2012 o 15:06 | odkaz na příspěvek
Lubomir
Příspěvků: 165
Zpráva odeslána: 13. 5. 2012 o 13:56 | odkaz na příspěvek
Platí do 27.5.2012
5.6mm x 14mm M3 Nylon Threaded Spacer (10pc)
http://www.hobbyking.com/buddy.asp?code=6B85C511-83DA-4213-9875-C16519CB4E1E Save US$: 0.67
Evotite CA460 Foam Safe Super Glue (Medium)
http://www.hobbyking.com/buddy.asp?code=23B1DBE7-EE8B-448E-B5F6-033D35F4CB00 Save US$: 1.18
Ultra Thin Foam Glue 40ml
http://www.hobbyking.com/buddy.asp?code=10011B05-7091-474E-96F5-EBF8594AE75B Save US$: 0.89
HobbyKing Super Glue CA (50g / 1.7oz) Med
http://www.hobbyking.com/buddy.asp?code=C151A737-CDD7-4CAB-8DF4-726CC473613B Save US$: 1.32
cypo.sk
Příspěvků: 80
Zpráva odeslána: 13. 5. 2012 o 17:39 | odkaz na příspěvek
Next
Příspěvků: 116
Zpráva odeslána: 21. 5. 2012 o 21:29 | odkaz na příspěvek
Lubomir
Příspěvků: 165
Zpráva odeslána: 26. 5. 2012 o 14:10 | odkaz na příspěvek
Platí do 9.6.2012
FrSky TAS-01 Telemetry Triaxial Acceleration
http://www.hobbyking.com/buddy.asp?code=862BD327-63E2-411D-B856-2E6C9515491F Save US$: 1.00
5.6mm x 21mm M3 Nylon Threaded Spacer (10pc)
http://www.hobbyking.com/buddy.asp?code=0E8D959B-1E91-48F8-9AE6-F846F319ECE7 Save US$: 0.77
6x3 Propellers (Standard and Counter Rotatin
http://www.hobbyking.com/buddy.asp?code=EF84D64E-45D9-42C7-94A1-7FFCA02B99E5 Save US$: 1.06
7x3.5 Propellers (Standard and Counter Rotat
http://www.hobbyking.com/buddy.asp?code=8B2C64EF-6DA2-4920-8B5A-CA16A3AA6F92 Save US$: 1.09
igoha
Příspěvků: 12
Zpráva odeslána: 26. 5. 2012 o 22:59 | odkaz na příspěvek
Lubomir
Příspěvků: 165
Zpráva odeslána: 10. 6. 2012 o 17:59 | odkaz na příspěvek
Platí do 15.6.2012
TURNIGY 4pcs hex socket driver set
http://www.hobbyking.com/buddy.asp?code=B36C8BBB-A553-4C66-B1F5-8C28108B9E49 Save US$: 0,60
9x5 Propellers (Standard and Counter Rotating) (6pc)
http://www.hobbyking.com/buddy.asp?code=ECCA9E08-ECD6-470F-AFF2-D3CEB99C2DCA Save US$: 1.25
8X4R Propellers (Standard and Counter Rotating) (6pc)
http://www.hobbyking.com/buddy.asp?code=EBB37286-6ADB-4982-A774-6CD488F66E24 Save US$: 1.15
Platí do 24.6.2012
http://www.hobbyking.com/buddy.asp?code=6C76D25B-6F80-41D0-9F9C-BEB6F67D5235 Save US$: 0,11
Turnigy Aerodrive SK3 2830 Series Replacemen
http://www.hobbyking.com/buddy.asp?code=BC029A0B-3E06-4543-AF77-DB05F4547811 Save US$: 0,55
MarkAurel
Příspěvků: 418
Zpráva odeslána: 12. 6. 2012 o 20:20 | odkaz na příspěvek
Štefko
Příspěvků: 103
Zpráva odeslána: 12. 6. 2012 o 22:36 | odkaz na příspěvek
igoha
Příspěvků: 12
Zpráva odeslána: 14. 6. 2012 o 13:57 | odkaz na příspěvek
MarkAurel
Příspěvků: 418
Zpráva odeslána: 21. 6. 2012 o 12:59 | odkaz na příspěvek
Find my codes here: http://hk.rc-international.info/swarm/markaurel (valid until July 05, 2012)
Extra-300L EP 36inch ARF (DE Warehouse) Save US$: 5.79
  • 414 ľudí online za poslednych 5 minút.
